Forums >> Revit Building >> Technical Support >> Rendering item
Tue, Jul 26, 2005 at 3:27:13 AM | Rendering item
Shanzie
Pepole, pepole, Does anyone know where i, or how i can't render a roof with hatching??? Cheers Shanzie
Tue, Jul 26, 2005 at 1:18:06 PM | RE: Rendering item
Xane
I think that you can't, only like material map. Make map like bitmap and assign to roof
Tue, Jul 26, 2005 at 4:45:58 PM | RE: Rendering item
pepsiqueen
pepsiqueen Avatar
I thought if the roof had a model pattern on it it would render.
Tue, Jul 26, 2005 at 6:01:53 PM | RE: Rendering item
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No the surface pattern applied in revit is completely independant of the accurender material. You would need to create an accurender material that utilises a bitmap as suggested by Xane.
ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
Thu, Nov 2, 2017 at 8:03:01 AM
Revit LT Select an Item
Fri, Dec 13, 2013 at 9:17:51 PM
filter/ deleting item
Thu, Sep 8, 2005 at 2:42:45 PM
Adjusting Graphic Display Options for Single Item?
Fri, Aug 5, 2011 at 5:01:03 PM
Deleting Detail Item
Tue, Sep 22, 2009 at 3:06:05 AM
Page generation time: 0.6860
