Forums >> Revit Building >> Technical Support >> can't select filled region
Fri, Jun 12, 2009 at 10:06:40 AM | can't select filled region
Sparhawk
I have placed several filled regions on a floor plan representing supply air duct.  Now I can not select and move them.  I tried hiding all elements around the region and I still can not select it.  This only occurs on one level.  On all other levels it can be selected.  Does anyone know what to do?
Fri, Jun 12, 2009 at 11:01:43 AM | can't select filled region
4 Stars: 205 Votes
Did you "Pin" those Filled Region??? Did you try to select by crossing and go to "Filter" to check if they appears???
Fri, Jun 12, 2009 at 11:34:47 AM | can't select filled region
cheryla
3 Stars: 2 Votes
Make sure the little box that says "Exclude Options" is unchecked- just in case you have design options set up.
Cheryl Nelson
Randall W. Hein Architects
Fri, Jun 12, 2009 at 11:36:41 AM | can't select filled region
emmettking
Also make sure in model objects that the line types used to make the border of the filled region are not hidden.
Fri, Jun 12, 2009 at 11:56:14 AM | can't select filled region
Sparhawk
I bet the lines to create the border were hidden or invisable because I had been using invisible lines earlier.  Is there a way to  change them given I can't select the area?
Fri, Jun 12, 2009 at 12:07:58 PM | can't select filled region
cheryla
3 Stars: 2 Votes
even if you created the region with invisible lines, you should be able to still select it. try the other suggestions and then change the region to use visable lines. Other than that, I can't think of anything else to suggest
Cheryl Nelson
Fri, Jun 12, 2009 at 12:09:26 PM | can't select filled region
Sparhawk
Yeah,  I created a new filled region making certain the lines were not invisible and I can select it.  So does anyone know how can I modify the earlier regions created with invisible lines?
Sat, Jun 13, 2009 at 10:02:29 AM | can't select filled region
Even with invisible line, you can tab select a filled region.... if you want to edit the region and change the line type you can.
Sat, Jun 13, 2009 at 10:15:54 AM | can't select filled region
Sparhawk
That is the problem.  I can not select it.  I can hide every element around the filled region and still can not select it either with tab-select or a crossing window.
Sat, Jun 13, 2009 at 12:21:12 PM | can't select filled region
4 Stars: 205 Votes
That is very wierd, even if you pin, if have invisible lines, if you change the Phasing, you could select it, picking in the border or by crossing, i don't get it....
Sun, Jun 14, 2009 at 1:26:12 AM | can't select filled region
lunchtrayrider
3.5 Stars: 7 Votes
are invisible lines turned off in the visibility settings for that view?
Sun, Jun 14, 2009 at 8:48:29 AM | can't select filled region
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Lunchtrayrider, in another thread (see the first one below), he said that he found the problem: "Thin lines, used to create the region, had been turned off."
Thu, Mar 28, 2013 at 11:56:00 AM | can't select filled region
#13
mariat
I had the same issue. Making sure my all Model Line categories were checked - fixed it.
Thank you!
Mon, Sep 21, 2015 at 4:24:58 AM | can't select filled region
#14
Drizzle123
i had this issue with a model i'd picked up after someone had left, and they had changed the override graphics in view settings by element and simply gave it a "hatch" style patten and a colour. Nice to know really saves you adding in extra elements to your model.
Fri, Jul 8, 2016 at 10:32:19 AM | can't select filled region
#15
pmartini2012
I too was having this issue and it was a function of the linework being turned off.  I went into VG, turned on all of my lines, and I was able to then select the filled region.  Very helpful, thank you!
filled regions...
Sat, Jun 13, 2009 at 4:48:38 PM
Filled region draw order won't work?
Thu, Oct 3, 2013 at 7:17:15 PM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Why won't my Filled Regions print?
Tue, Sep 2, 2008 at 3:38:22 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
Page generation time: 0.4676
