Forums >> Revit Building >> Technical Support >> Materials & Rendering
Thu, Jun 11, 2009 at 9:11:23 PM | Materials & Rendering
onematt
Hi,
I am using REVIT 2010. I am trying to apply a few different colourbond image files so that i can produce a rendered image. I have set a about four different materials and each of them will have a separate image file. The problem ive got is when i change one of them, all the rest of the images become invalid so only one works at a time.
Can anyone explain why this might be happening.
Also does anyone know when an update might a available that will be fixing some of the bugs in 2010?
 Thanks, Matt
Fri, Jun 12, 2009 at 4:45:25 AM | Materials & Rendering
4 Stars: 205 Votes
Are you trying to put 4 different materials in ONE layer? One object??? is that??
Fri, Jun 12, 2009 at 7:14:51 AM | Materials & Rendering
tim123
4 Stars: 19 Votes
I found that in 2010 it helps to have the custom images / maps in a single folder and have a link to that folder in the rendering options.
Sun, Jun 14, 2009 at 6:32:52 PM | Materials & Rendering
onematt
no. i have four different layers. the image file i assign to them becomes invalid on all other layers as soon as i set another.
thanks tim ill give that a go hopefully it sorts itself out.
Basic Rendering Question: Are .bmp & .tiff images usuable for materials?
Thu, Oct 26, 2006 at 5:25:40 PM
Rendering Materials
Wed, Sep 13, 2006 at 1:13:06 PM
Revit materials missing at rendering [ 1 2 ]
Tue, Jun 14, 2011 at 11:24:21 PM
22
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:55 AM
13
some materials not rendering in perspectives
Thu, May 23, 2013 at 3:00:34 PM
Page generation time: 0.4131
