23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Elevation marker prefix
10 Posts No Rating |
How can I change the text on an elevation marker to read 0'-0" instead of 0"? (I'm using RA2009). The elevation properties dialog says the elevation is 0' 0", but that's not how it shows up on screen. I just think it's silly to  for example) have a second floor elevation read as 12'-6", but the first floor read as 0". It seems like there should be an option for a prefix, like what's possible for a linear dimension.
Look at your project units settings - length. The box "suppress 0 feet" has been checked - uncheck that box.
Awesome. Thanks!
Actually, this won't work. It forces all dimensions throughout the project to have the "zero feet" unsuppressed. So anywhere I use linear dimension strings, it will affect the dimensions...so if I want a detailed dimension to just show as 2", now it shows as 0'-2". Is there a way to divorce the way elevation markers are treated vs. linear dimensions?
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
Adding a reference elevation to an existing elevation marker? |
Wed, Sep 17, 2014 at 7:57:46 AM
ELEVATION MARKER |
Thu, Sep 10, 2009 at 2:55:39 PM
If your elevation markers on plan disappear. |
Fri, Mar 4, 2016 at 3:40:45 PM
One View Elevation Marker |
Wed, Jul 9, 2008 at 6:27:41 AM
