Forums >> Revit Building >> Technical Support >> Adding Windows To Building: Help Needed Please
Wed, Jun 10, 2009 at 12:02:31 PM | Adding Windows To Building: Help Needed Please
ksmith
I wonder if anybody can help with this please. I want to add windows to a building but can't seem to do so because I am not using a wall. I can only describe this by saying that I am adding a conservatory and I need to add windows on to a small dwarf wall. The windows are therefore going on top of the wall and up to the roof line at first floor level.
When I try to add a window on top of the dwarf wall that I have, Revit will not allow me to do it. The only way that I can add the window is if I take the wall all the way up to the first floor level and then insert the window into the wall.
I know that you can use a curtain wall or storefront wall but when I do this the window is completely clear with no detail, i.e, mullions etc.
Any ideas anybody?
Thanks
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Wed, Jun 10, 2009 at 12:25:57 PM | Adding Windows To Building: Help Needed Please
4 Stars: 205 Votes
Use the curtain wall, then apply the mullions you want....
Wed, Jun 10, 2009 at 1:10:05 PM | Adding Windows To Building: Help Needed Please
ksmith
Hi Typhoon
Thanks for that. I now have my mullions looking better but how do I now make the curtain wall look more like conventional windows. I need to add a transom and some openers in the windows etc.
Many thanks
Wed, Jun 10, 2009 at 1:27:28 PM | Adding Windows To Building: Help Needed Please
4 Stars: 205 Votes
Simple, pick in that curtain wall then in the options bar pick in "Edit Profile", create lines inside of the curtain wall, that create the openings....
Wed, Jun 10, 2009 at 2:21:02 PM | Adding Windows To Building: Help Needed Please
ksmith
Typhoon, that seems so simple now... Thank you. Just one final thing on this matter if that is OK. Is it possible for me to add an exterior window sill to the bottom of my curtain wall, just to finish it all off nicely?
Thanks again for the advice so far as always.
Wed, Jun 10, 2009 at 2:51:37 PM | Adding Windows To Building: Help Needed Please
4 Stars: 205 Votes
Sorry for the delay but like what??? images what are you trying to do?
Wed, Jun 10, 2009 at 3:07:01 PM | Adding Windows To Building: Help Needed Please
ksmith
I have attached an image if it will help. I am basically trying to fit a window sill underneath the curtain wall as you wouls see underneath normal windows. On the image here, if you look to the left you will see some normal windows that I have placed and they have sills at the bottom. To the right of those windows on the next bay along, I have placed the curtain wall we were refering to. It is at the bottom of that curtain wall where it rests on the brickwork that I want a sill added. I am not sure how to achieve this.
Hope this image helps a little.
Many thanks
Wed, Jun 10, 2009 at 3:14:31 PM | Adding Windows To Building: Help Needed Please
4 Stars: 205 Votes
Ohhh, i was think in other thing, well it's simple, you can do that in several ways but now the faster is create in place with solid sweep the profile you want (on top of the wall) and give it a material you want..., do you get it???
Wed, Jun 10, 2009 at 3:57:31 PM | Adding Windows To Building: Help Needed Please
ksmith
lol.. you always seem to have the answers Typhoon. No I don't get it just yet but I will do some reading later on about in places and creating sweeps.
Thanks  or help so far... greatly appreciated
Wed, Jun 10, 2009 at 3:59:59 PM | Adding Windows To Building: Help Needed Please
4 Stars: 205 Votes
I'm upload a video for you with this, wait....
Wed, Jun 10, 2009 at 4:05:59 PM | Adding Windows To Building: Help Needed Please
#11
ksmith
that is great, thanks. look forward to seeing it!
Wed, Jun 10, 2009 at 4:07:33 PM | Adding Windows To Building: Help Needed Please
#12
4 Stars: 205 Votes
there it is: http://www.megaupload.com/?d=VJ8AQU1H
Wed, Jun 10, 2009 at 4:49:06 PM | Adding Windows To Building: Help Needed Please
#13
ksmith
Typhoon, that video was fantastic. Everything is very clear now and I will get cracking on with the project. Can't thank you enough for all the great help you give. At this rate and a little bit of luck, I will soon be able to start designing and building buildings on Revit instead of building them with my hands!!! Too much hard work...lol
Thank you
Best Regards
Kirk
Help Needed To Split Face and Add Windows
Fri, Jun 26, 2009 at 5:36:49 PM
Adding windows that are alligned to a sloped roof
Tue, Jan 31, 2012 at 7:54:52 AM
Adding a second floor into a six story building
Thu, Aug 21, 2014 at 12:02:52 PM
URGENT!!!! WINDOWS NEEDED
Sat, Jun 20, 2009 at 6:39:01 AM
Windows needed for vacation home design
Tue, Jul 30, 2013 at 4:29:11 PM
Page generation time: 0.4312
