Forums >> Revit Systems >> Technical Support >> Need to change material on ducts. They are rendering as black masses?
Wed, Jun 10, 2009 at 10:56:26 AM | Need to change material on ducts. They are rendering as black masses?
lrcarr048
I am working in Revit MEP and need to render pictures of the duct system. When I do, it comes out black. Normally that happens when there is no material parameter in the family. I checked the family and there was not. So I go to edit the family and it is grayed out in the right click menu. I was able to edit the fittings and add a parameter to put a material on them but could not edit the ducts. I also tryed to open "System Family: Rectangulart Duct" directly from the Imperial library but I could not find it. My company has alot of hours in this project and this is holding the whole thing up.
Thank you for the help
Thu, Jun 11, 2009 at 12:14:39 PM | Need to change material on ducts. They are rendering as black masses?
lrcarr048
I did find a solution. I went to the "Object Styles" and changed the material there. The only problem is there is not a setting for the actual duct. What I had to do is set the insulation material and put a 1/8" of insulation on all the duct. This was the only solution I could find. If anyone has a better one let me know.
Custom Material Rendering black
Thu, May 31, 2012 at 5:04:30 PM
Custom material Rendering Black
Tue, Sep 22, 2009 at 2:54:01 AM
custom material render black (i find, one anser)
Mon, Apr 25, 2011 at 9:27:42 AM
Custom Materials Rendering Black
Tue, Jul 13, 2010 at 5:42:22 PM
Reverting a mass to material <by category>
Thu, Jun 14, 2018 at 3:18:10 AM
Page generation time: 0.5754
