29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Pad changes topography
3 Posts No Rating |
I am new to Revit and am try to learn Revit 2010. The problem I am having and can not seem to find a way around is that when I create a building pad on my topography it changes the topography. I do not want this to happen as I am trying to create the existing site with existing buildings. I have attached (hopefully) a before image and an after image so that you can see what it is doing. Any suggestions as to how I can stop this from happening?
The problem is that REVIT creates the contours from know data and interpolates for all points between that know data. When you place your pad, it interups that process and revit assumes a new pont at the edge of the pad. You need to give REVIT some additional points... maybe along the pad line or just more points along the contour before you add the pad.
Like thus....
3 Posts No Rating |
Thank you so much for your help. That worked perfectly.
Building Pad Altering My Topography Surface |
Wed, Nov 30, 2011 at 12:01:59 PM
Existing pad not cutting topography properly. |
Mon, Jun 7, 2010 at 7:27:40 AM
Revit Topography Cut Hatch only shows up under Building Pad |
Fri, Feb 24, 2017 at 11:31:36 AM
pad on topography |
Wed, Apr 20, 2005 at 12:15:53 AM
Cannot cut below grade sections with any depth after topography placed |
Mon, Jun 20, 2011 at 3:56:39 PM
