Forums >> Revit Building >> Technical Support >> grids are disappearing
Tue, Jun 9, 2009 at 12:22:06 PM | grids are disappearing
cheryla
3 Stars: 2 Votes
I have a project where I have alrady laid out a grid. They have been working fine for several months, then they magically vanished. They are not hidden, and I have checked the scales, checked the hidden items...
We also tried drawing new grids, but when we try to rename them to what they were before, it says that there is already a grid with that number. Any thoughts???
Sorry- rush on this- deadline Thursday on this project!!!!!!
Cheryl Nelson
Randall W. Hein Architects
Tue, Jun 9, 2009 at 12:27:11 PM | grids are disappearing
No magic ....   The grids are still in your project.  Have you enebled worksets?  Is the workset on that has your grids?  You don't say - did you check VG?
Tue, Jun 9, 2009 at 12:32:24 PM | grids are disappearing
tim123
4 Stars: 19 Votes
Can the grid lines be seen in any elevations or sections?  The depth and height that the grid lines extend to can be adjusted in these views (when the 3d indicator is on).
Also, if you create a new plan does it show grid lines?  If so, they are probably hidden in the other views.
Tue, Jun 9, 2009 at 12:44:21 PM | grids are disappearing
cheryla
3 Stars: 2 Votes
I tried all of those things- nadda.
 I found two of the grids in a callout, but even when I expand the crop region, none of the others are visable. I am wondering about the 2D/3D options on the grid lines. The two grids that I found were set to 2D in the callout. I am wondering if  that has anything to do with it.
Cheryl Nelson
Tue, Jun 9, 2009 at 12:47:52 PM | grids are disappearing
tim123
4 Stars: 19 Votes
Click on the 2D and it will change to 3D.  See where it extends to.
Tue, Jun 9, 2009 at 12:48:50 PM | grids are disappearing
cheryla
3 Stars: 2 Votes
Ok, I figured it out.
 if you find one, click maximize 3D extents, then you can click select all instances, and maximize 3D extents again for all of them.
Thanks for the help everyone.
Cheryl Nelson
Tue, Jun 9, 2009 at 12:54:04 PM | grids are disappearing
4 Stars: 205 Votes
Just a question, Did you check in VG in Annotation categories - Grids?
Tue, Jun 9, 2009 at 1:01:37 PM | grids are disappearing
cheryla
3 Stars: 2 Votes
Yeah, I checked everything I could think of in the settings. I stilll am not sure WHY it happened, but I fixed it, so I'm happy.
Cheryl Nelson
Thu, Oct 28, 2010 at 1:15:36 PM | grids are disappearing
grimberg
Hi Cheryl,
It happens the same to me. How did you do it? Please explain.
Thu, Oct 28, 2010 at 1:36:30 PM | grids are disappearing
Read this in your HELP: Example of Datum Visibility in Project Views
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
2D and 3D Grids
Wed, Oct 17, 2007 at 10:04:13 AM
Page generation time: 0.1230
