Forums >> Revit Structure >> Technical Support >> convert imported single line text to mutiline text?
Tue, Jun 9, 2009 at 12:13:25 PM | convert imported single line text to mutiline text?
workforlife
is there a way to convert imported single line text to mutiline text?
Tue, Jun 9, 2009 at 12:23:58 PM | convert imported single line text to mutiline text?
All text in REVIT is multi-line
Was your question really how do you combine imported single line text?  I end up cutting an pasting.  If the original in CAD can be opened at the same time, it is sometimes easier to copy clip the multi-line text and paste into revit on the first line and delete the following single line imports.
Sorry - I know that is a PITA answer.....
Tue, Jun 9, 2009 at 12:42:35 PM | convert imported single line text to mutiline text?
workforlife
it works thanks!
Mon, Oct 1, 2012 at 9:45:50 AM | convert imported single line text to mutiline text?
luismendez
I know this know this might be late, but go to:
Here is the link to Revved Suite of tools. Great set of text tools' and free, just AMAZING!!!!
I used to import construction notes from autocad but it was a pain, this extension work just perfect. Change lower case yo Uppercase, an so on...
cheers
2D DWG Convert to 2D Revit
Mon, Nov 23, 2015 at 1:57:38 PM
Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
Wed, Dec 29, 2010 at 5:27:08 PM
Black background on text (imported DWG)
Thu, Feb 18, 2016 at 8:38:47 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Changing Text Size in a text box
Thu, Aug 6, 2009 at 6:41:13 AM
Page generation time: 1.3971
