16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Setting Wall Sweep to Detail Levels
I searched around on the forums for something relating to this but wasnt able to find anything about it. I have added a thin 1/8" thick wall sweep for some bathroom tile. Is there a way that i can set that wall sweep to show up on find detail only? but still show the correct dimension when it is on medium detail?? any suggestions are greatly approved. Allen
J. Allen Ball Revit Architecture 2010 Certified Professional |
You did this as a sweep? I do wall tile now as a seperate thin wall and sometimes a stacked thin wall if the base is different or if there is a wainscot. Then I put those in a different workset and control through my view templates.
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:44 PM
19
Wall Sweep with Detail |
Wed, Jan 6, 2016 at 12:02:49 PM
Cutting a Sweep - Brick Detail |
Sun, Jan 4, 2015 at 3:37:41 PM
Wall sweep won't trim |
Tue, Apr 25, 2017 at 2:07:17 PM
why do wall sweeps define the wall height? |
Fri, Mar 6, 2009 at 12:57:04 PM
