18 Users Online (16 Members):
Forums >> Revit Building >> Tips & Tricks >> Modifying Text Leaders in 2010
I have tried doing this by making separate families and tweeking the leader that way, but here is my question: Is there a way to close the gap between the end of the text and the beginning of the leader. Sometimes I may have a short description and the leader is way out to the right of my left-justified text. Of course, if my leader is on the left side, it looks fine. Does anyone have any tips on how to adjust the beginning ot the leader so it is closer to the end of the text?
change the justification of your text and the leader will behave properly. that is, unless you absolutely require that all of your text have the same justification. in that case, you'll simply have to shrink or expand your text box until it looks good.
Revit 2010 - It's a good thing... Stop Fighting it. |
I'll try that, thanks
Cannot turn on leaders for text boxes inside custom annotation. |
Wed, Aug 13, 2008 at 9:10:58 AM
Leaders contrained to angles without text |
Thu, Jan 11, 2007 at 5:15:00 PM
Problem with text leaders when using crop regions |
Fri, May 6, 2011 at 8:24:33 AM
Leaders moving_Annoying |
Fri, Jan 20, 2012 at 7:37:30 AM
Multiple leaders in Keynote Tag ?? |
Fri, Jun 28, 2013 at 8:46:43 AM
