19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> View range seting for plumbing familey
Hi there Why when create object element on floor plans – Ref’ Level - using plumbing fixture family no matter how I set the view range , I always see the element as if I am looking at it from above, but if I build the same object using generic model template the cut plan of that object on floor plan is OK? nirim
30 Posts No Rating |
Plumbing Fixture category doesn't allow what you want. Generic model category allows cutting the family in plan view.
Hi sagarkgathara Thanks for your answer, the thing is that I want to be able to tag and schedule the element with the other plumbing elements. nirim
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
