Forums >> Revit Building >> Technical Support >> MISSING elevation tags
Fri, Jun 5, 2009 at 9:43:07 AM | MISSING elevation tags
jleede1
All of the elevation tags are missing in the floorplan.  The views are still there, but no tags.  They are not hidden or outside the crop region- I've already checked.
Fri, Jun 5, 2009 at 10:34:00 AM | MISSING elevation tags
tim123
4 Stars: 19 Votes
When you say they are not hidden, are you referring to the temporary hide or the hide in view?  Click on hte light bulb to confirm.  Are elevations on in VG?
Fri, Jun 5, 2009 at 11:17:36 AM | MISSING elevation tags
jleede1
I've clicked the lightbulb and they are not there.  I've also already checked the visibility graphics, and Elevations are checked.
Fri, Jun 5, 2009 at 1:26:43 PM | MISSING elevation tags
tim123
4 Stars: 19 Votes
If you create a new floor plan do you see them?
Mon, Jun 8, 2009 at 1:46:44 AM | MISSING elevation tags
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Check the Phases...
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Mon, Jun 8, 2009 at 9:30:10 AM | MISSING elevation tags
LIZARD2806
3.5 Stars: 7 Votes
If phases doesn't work, also check to make sure the you turned off crop view.
Mon, Jun 8, 2009 at 3:20:09 PM | MISSING elevation tags
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
a comon issue that i run into is that the elevation tags are simply outside of the crop region.  expand your crop region and  they'll likely appear.
Revit 2010 - It's a good thing... Stop Fighting it.
Tue, Jun 9, 2009 at 8:13:53 AM | MISSING elevation tags
MARS1276
1 Stars: 1 Votes
Or take a look at your visibility graphics.  Under 'Annotation' it may simply be unchecked for that view.
Tue, Jun 9, 2009 at 9:55:21 AM | MISSING elevation tags
tim123
4 Stars: 19 Votes
jleede1 has noted that the VG has been checked.  It may be that the elevation tag has been set to 'not show in views courser than', so it may be the scale of the view.
Mon, Sep 17, 2018 at 10:55:17 AM | MISSING elevation tags
ZRYarnell
I know this thread is a bit old but I figured I would post my solution for anyone still searching out there...
If none of the previously mentioned issues are the culprit don't forget to check the "Filters" section under your V/G setting or in your view template. I am working as a consultant on a project where we are using the other firms view templates and they had set up filters to hide certain elements.
elevation tags!!!!!!!!!!!!!!!!!!!!
Fri, Apr 24, 2009 at 5:44:23 PM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Missing Elevation Tag
Thu, May 7, 2015 at 7:32:03 AM
How do you change the look of the Elevation Symbol
Thu, Sep 14, 2006 at 5:15:43 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Page generation time: 0.5963
