13 Users Online (11 Members):
Forums >> General Discussion >> Revit Project Management >> DWF Publishing in 2010
Hey everyone! I sent out a job to “Ridgeway’s”, to be plotted. And here is the message I’ve received. I’m unable to process these files. Is it possible to send a pdf or a tiff? When I was using “Revit 2009” I just publish the sheets to DWF format and sent them out. But with Revit 2010, for some reason the files will not plott. I have talked with one of the operators, and he has told me that they are using the latest version of “Autodesk Design Review”. The file opens up on the monitor, but it will not plot. I never had this problem in 2009.
Is there something I'm doing wrong?
Wierd, right now i'm plotting with the new "Autodesk Design Review 2010" files from Revit 2010, I'm not publish the sheets but export to DWF 2D and no problem at all... did you check the "Print setup" before publish? And in Autodesk Design Review did you choose the right printer with the right settings? Wierd...
Thinks, Typhoon It sounded wierd to me also. You see I'v never had that problem with in 2009...... I also exported the files to DWF. And then I (E-mail the files to "RIDGEWAYS" . I guest, I'll send the printer selector instruction with the next project...........Typhoon, check this out....One of the sheet "printed out" from another project, but part of the front wall was messing. Wierd... "Ha"?
Publishing a .dwf File |
Fri, May 27, 2011 at 1:42:00 AM
uNRECOVERABLE ERROR WHILE PUBLISHING .DWF SET |
Tue, Feb 13, 2007 at 1:53:26 PM
publishing dwf files |
Wed, Jun 2, 2010 at 12:31:48 PM
DWF Linking |
Thu, Aug 23, 2007 at 12:55:32 PM
Printing Issue 2010 |
Wed, Sep 2, 2009 at 2:50:19 AM
