Forums >> General Discussion >> Revit Project Management >> Exterior Floor Question
Thu, Jun 4, 2009 at 12:24:19 PM | Exterior Floor Question
THEBEN
Hello,
 I am making a house in revit architecture. Its fairly basic. Its a two story house, and between the first and second floor walls i have the floor. And it puts a space inbetween the walls. and the exterior doesnt match the siding on my house. is there a way to change this?
I have a picture if you need a reference
Thu, Jun 4, 2009 at 12:45:14 PM | Exterior Floor Question
4 Stars: 205 Votes
"And it puts a space inbetween the walls." - ???
"and the exterior doesnt match the siding on my house" - Are you talking about to flip the walls?? what is interior must be exterior?
Thu, Jun 4, 2009 at 12:57:38 PM | Exterior Floor Question
THEBEN
http://i94.photobucket.com/albums/l109/Ben-Richardson/3D2.jpg
if you look at this, between the first and second floor there is a space. Is there a way to make that match the siding on the house?
Thu, Jun 4, 2009 at 1:13:04 PM | Exterior Floor Question
4 Stars: 205 Votes
In a "Elevation view" your walls are touching the second level line? pick in the wall and go to properties, check the "Top constraint" and "Top Offset"....
Thu, Jun 4, 2009 at 3:55:58 PM | Exterior Floor Question
THEBEN
So by doing that, your saying the gap between the top of the first wall and the bottom of the second floor wall where the floor is wont be there? I dont have revit with me right now, ill be on it later.
And Thank You BTW
Thu, Jun 4, 2009 at 6:00:25 PM | Exterior Floor Question
4 Stars: 205 Votes
check that please...
Thu, Jun 4, 2009 at 8:38:14 PM | Exterior Floor Question
erland73
erland73 Avatar
4.5 Stars: 85 Votes
THEBEN, I think that when you are creating the second floor (slab) and you finish the sketch, Revit ask you if you want the first level walls to attach the bottom of the slab and you pick YES. See the images attached and compare the difference if you pick yes or no....
These are if you pick NO..
Edited on: Thu, Jun 4, 2009 at 8:40:36 PM
Thu, Jun 4, 2009 at 8:40:02 PM | Exterior Floor Question
erland73
erland73 Avatar
4.5 Stars: 85 Votes
And these are if you pick YES....
Fri, Jun 5, 2009 at 11:54:16 AM | Exterior Floor Question
THEBEN
I did that, but does it have to be a slab, or can it be the 12" Carpet finish?
Fri, Jun 5, 2009 at 2:17:52 PM | Exterior Floor Question
4 Stars: 205 Votes
Hi see the video: http://www.megaupload.com/?d=2S3FANNS
exterior finsh below zero
Sun, Apr 11, 2010 at 10:13:36 AM
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 6:11:13 PM
Stairs: multistory top level question.
Thu, Aug 16, 2007 at 11:44:38 AM
Modifying floor slabs/foundation footings??
Thu, Aug 27, 2009 at 3:35:33 AM
Question about rendering in Revit Architecture 2009
Tue, Feb 23, 2010 at 2:57:38 PM
Page generation time: 1.5735
