22 Users Online (20 Members):
Forums >> Community >> The Studio >> BRICK VENEER WALL
I NEED TO CREAT A BRICK VENEER WALL WITH THE BRICK ONLY TO BE 1200 HIGH WITH THE REST AL THE WALL FULL HEIGHT. CAN YOU HELP??
I replied to this in your wishlist post - check it out.
I would recommend using a stacked wall system, where you take two wall types and stack them. YOu can define one to be at that 1200 height. Another way is to modify the materials you have for that wall. If you click on edit, structure,click on preview and preview in section you get some bottons become available to you. Click on the one for split region and select the brick, then just move that split line to the height you want. THen assign a layer to the remainder face of that wall to be what you want it to be. The Revit tutorials offer good examples on how to modify walls. HTH.
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
Stone Wall |
Tue, Aug 20, 2013 at 3:55:33 PM
Brick veneer stepping at alternate elevations |
Wed, Aug 14, 2013 at 8:28:36 PM
brick veneer window insertion question |
Tue, Nov 23, 2004 at 4:28:49 PM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ] |
Wed, Feb 4, 2009 at 11:22:19 AM
15
