14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> tagging slab level and thickness?
2 Posts No Rating |
in RAC 2008, is there a way to tag a slab's thickness and level, i've only been able to tag its type or family name...
You can not create a tag that will "read" a slab thickness. But, you can create a shared parmeter that is assigned to floors to host this value as a type parameter. Now you can create a tag to read that. Again, you can't get a tag to read a level. You can do the same as above but make an instance based parameter (I think). Levels will show up in floor schedules.
2 Posts No Rating |
thanks for the reply hub, ill try it.
slab schedule |
Mon, Apr 19, 2010 at 9:10:27 AM
Metal decks spanning in different directions on the same level |
Mon, Nov 9, 2009 at 7:52:16 PM
Wall line thickness |
Mon, Sep 26, 2005 at 5:47:35 PM
Suspended Slab problem |
Thu, Aug 19, 2010 at 3:15:32 AM
Slab Thickness Tag |
Fri, Aug 28, 2009 at 7:16:44 AM
