18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Walls not showing 2010
37 Posts No Rating |
I was on level 4 and drew some non-load bearing walls. then i changed their constraints to go from level two to level six. Fore some reason they are not showing above level 4. Actually they ARE showing as gohsted below. i can touch them and check their properties. Properties say they should go from 2-6 but they are not dark. Any ideas? I'm stumped...for a newbie. Thanks in advance fro any help. -Eric
never mind. My walls were attached to the level above....
Great - thanks for posting after you found the solution. We encourage all posters to do that. FOR ALL NEWBIES: As an explanation of what ejm159 discoverd, no matter what height the wall is set to, if the top... or bottom is set to attach to a floor or roof, it will extend or be shortened as needed to attach. BUT IT WILL STILL SHOW ITS INITIAL HEIGHT IN POROPERTIES - NOTE THE CHECKED ATTACHED TOP/BOTTOM TO SEE WHEN THIS HAS HAPPENED
In shaded View walls/roofs are showing material and lines behind them |
Tue, May 28, 2013 at 9:35:44 AM
Walls not showing in plan region |
Mon, Feb 18, 2008 at 1:59:12 PM
14
Walls Wont Show Up In View After Upgrading From 2010 To 2011 |
Tue, Dec 21, 2010 at 11:00:20 AM
Walls not showing in print |
Tue, Jun 14, 2022 at 9:51:43 PM
stacked walls 2010 |
Wed, Jun 3, 2009 at 5:06:33 PM
