16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 - 3D max 2010 finishes
14 Posts No Rating |
Does anybody know is it possible to Export Revit 2010 Model to 3D Max without loosing finishes or I need to re-apply it in Max? If yes, please share the knowledge. Thanks a lot!
Did you try to export in FBX?
You should do a little research. perhaps here http://area.autodesk.com/ or maybe augi.com. There are threads on how to import your model into a max scene then xref that scene into a master max file. This allows you to update your Revit model without losing your master scene file settings.
Thanks I will check it out tomorrow. Augi and Autodesk. )
Revit 2010 to 3ds Max 2010 Problem |
Thu, Jul 30, 2009 at 9:31:25 AM
problems inporting from revit 2010 to 3ds max 2010 |
Sun, Mar 13, 2011 at 6:17:59 AM
Revit 2010 to 3ds Max Design 2010 vray 1.5 SP4 |
Fri, Sep 10, 2010 at 1:59:46 PM
Opening a 2010 file in 2009 |
Thu, Jul 16, 2009 at 8:51:56 AM
3ds Max-3ds Max Design 2010 |
Thu, Apr 16, 2009 at 12:15:17 PM
