Forums >> General Discussion >> Revit Project Management >> Schedule and Tags
Wed, Jun 3, 2009 at 2:28:29 PM | Schedule and Tags
Sigfinnur
Is there a way to make the Door Tags behave like the Window Tags? Without the sequential input so the samy door type has the same Tag number/letter?
I am also having difficulties listing curtain wall windows on the window schedule. Because they behave like doors. I have made a seperate schedule for them and deleted the headers and just added them under the Window schedule on the sheet. Is there another way to do this?
 Furthermore, when grouped/sorted by width the width of the curtain wall does no seem to show up on the schedule. It has to do with the accuracy. My unit settings is set to round up the the nearest 1/4".  How can I tell the window schedule to round up as well and group them together?
Thanks,
Finn.
Wed, Jun 3, 2009 at 2:40:57 PM | Schedule and Tags
Sigfinnur
I have the first question figured out.
For those who have the same problem:
By editing the Label in the tag family and setting it to "type mark" they will behave like the window tags.
Finn.
Fri, Sep 23, 2011 at 11:57:29 AM | Schedule and Tags
sroreilly
AHA!
Thank you for posting your solution.
Fri, Sep 23, 2011 at 12:09:10 PM | Schedule and Tags
Even if they are instance tags, doors and windows can have the same number.  You will get an error that you can just ignore.
Fri, Sep 23, 2011 at 12:13:07 PM | Schedule and Tags
If you don't want to schedule every instance, did you know you can filter your schedule?  We added a project parameter to all categories which is "DO NOT SCHEDULE".  Then we filter our schedules to exclude all elements with "X" in tyhat parameter (and hide this column in the schedule).
When you do the above, you don't have to "fix" every instance.
Fri, Sep 23, 2011 at 2:32:25 PM | Schedule and Tags
Schedule sorting with letters
Thu, Jun 16, 2011 at 7:00:17 AM
no value in my tags
Wed, Mar 30, 2011 at 7:56:29 AM
Is it possible to filter tags? or schedule them?
Mon, May 3, 2021 at 8:57:58 AM
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Page generation time: 0.5597
