12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> ? Protecting an RVT file from future use
26 Posts No Rating |
A client wants my rvt file as a part of the work product, but I don't want them (or anyone else) to be able to use or change it in the future as a base for any drawings (for liability & copywrite reasons). Is there a way to protect Revit files so that they are fully viewable & functional in revit, but unable to be changed, copied, or added on to? With autocad I used to just bind & explode all the objects and put everything on 1 layer before giving to clients (so it's pretty much impossible to use as anything other than an overlay) Is there anything you can think of that's synonomous to that in Revit? Thanks
Give him a 3D dwf with all the 2D dwf sheets inserted in the same file. Otherwise forget it. Revit files can not be locked.
Problem With Linked RVT Files and Associated Levels |
Tue, May 29, 2012 at 2:10:14 PM
Linked rvt into another rvt |
Tue, Jan 20, 2009 at 12:21:13 PM
Revit Template File from Project file .rvt to .rte |
Sun, Apr 28, 2013 at 1:35:39 AM
Help! How to save a template file as an rvt file? |
Wed, Aug 20, 2008 at 11:27:01 PM
Need to convert RVT file to RFA |
Sat, May 22, 2021 at 6:14:06 PM
