19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> export layers, purge
95 Posts No Rating |
Hello, I started setting up the export layer settings for DWG, and decided to set all layers to 0 first and then go back and assign the correct layer name. I noticed there are some remnants from imported CAD files I used to convert some details. I've long removed those files, but some still appear in this list (see image). I've checked the Link Manager, Imported Objects under Object Styles, and I've removed all views so the actual CAD files couldn't be used anymore. Any suggestions on cleaning this up? Thanks
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer |
How about families?
Imported layers still active when exporting |
Fri, Feb 26, 2010 at 8:44:40 AM
Export fills to layers |
Fri, Sep 11, 2009 at 11:51:47 PM
Export all properties BYLAYER, and create new layers for overrides. |
Fri, Nov 14, 2014 at 12:22:28 PM
REVIT 2013 - Export DWG Layers Text File Location |
Fri, Aug 3, 2018 at 4:44:52 PM
How to export CAD with custom subcategory layer |
Tue, Feb 15, 2011 at 10:08:37 AM
