Forums >> Revit Building >> Technical Support >> Render doesn't work
Thu, Jul 21, 2005 at 6:18:43 PM | Render doesn't work
Aaron
Hi...whenever I go to render a view I setup the scene, hit render, hit go, and nothing happens...whats wrong? Using Revit 8 by the way
Mon, Jul 25, 2005 at 8:49:37 AM | RE: Render doesn't work
eldados
eldados Avatar
4.5 Stars: 8 Votes
how much ram do you have? and how big is the file you are trying to render? try lowering the quality of the render and see if you can do it, also try to restart Revit and clear some ram...
Mon, Jul 25, 2005 at 12:42:50 PM | RE: Render doesn't work
Aaron
No...it wasn't any of that...I use a Dell Dimension XPS (plenty of power) it was rendering fine, and then all of the sudden it wouldn't render anymore. Im pretty fluent in Revit and have never had a problem like that....I ended up having to copy the model from the site plan view and pasting it in a new project template. It worked fine after that....I just had to reassign all of my materials. Oh well. Thanks.
Mon, Jul 25, 2005 at 5:56:41 PM | RE: Render doesn't work
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yeah i've had this before also. It's usually some sort of corruption in the revit database. Best to send the file to support. Even if you have it resolved still send the file to support so they can work on avoiding having this happen again the future.
Mon, Jul 25, 2005 at 6:20:29 PM | RE: Render doesn't work
Aaron
i'll do that...glad I'm not the only one this has happened to. Thanks.
Mon, Jul 25, 2005 at 6:47:55 PM | RE: Render doesn't work
eldados
eldados Avatar
4.5 Stars: 8 Votes
Smile you are not alone, I have had this problem in the past...
Fri, Mar 14, 2008 at 3:58:55 PM | Render doesn't work
gottabedrew
I am in the same boat, just found out the 300K sf building we have been working on will not render in revit.
Tried to export out as dwg to use in VIZ no luck keeps crashing.
options at this point are to pull a backup that is still able to render and continue from there?
or would it be best to start over?
thank you
Andy
Material's render a different color
Thu, Oct 20, 2011 at 8:08:58 PM
Jeep family won't render
Thu, Mar 30, 2006 at 5:38:10 AM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
First Render
Sat, Jan 21, 2006 at 12:51:06 PM
Rendering material doesn't show up
Thu, May 5, 2011 at 10:52:13 AM
Page generation time: 6.2066
