Forums >> Revit Building >> Technical Support >> 09' Rendering Issue
Wed, Jun 3, 2009 at 9:13:38 AM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
I am trying to render and interior shot.
I have rendering this view 1,000 times for test runs on materials, and etc.....All the sudden I am not sure what is going on I have accidentally selected something and it is chopping my rendering at a certain height. I have checked all the settings I know of that has to do with rendering and crop region, etc...
Any help would greatly be appreciated. Thank you
I have attached to examples of rendering on the draft setting, The Ceiling height for the first one is 10'-6" and the second is at 12'. So somewhere in between those two heights there is an issue.
Wed, Jun 3, 2009 at 11:30:28 AM | 09' Rendering Issue
tim123
4 Stars: 19 Votes
I can't see much from the images, but are you sure that you are not moving the ceiling above the floor above?
Wed, Jun 3, 2009 at 11:37:26 AM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
there is no floor above
Wed, Jun 3, 2009 at 11:40:56 AM | 09' Rendering Issue
lunchtrayrider
3.5 Stars: 7 Votes
usually black would indicate some material issues.  other then that i don't have a good guess.
I like scooters. and motorcycles.
Wed, Jun 3, 2009 at 11:49:36 AM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
I would probably have to rule out the material issue b/c everything is the same in the 2 different photos. The only thing i changed was the ceiling height.
Wed, Jun 3, 2009 at 12:02:38 PM | 09' Rendering Issue
tim123
4 Stars: 19 Votes
Are you using a section box?
Wed, Jun 3, 2009 at 12:07:23 PM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
No, it just seems like there is this imaginary cut line at 11' or so, somewhere in that area
Wed, Jun 3, 2009 at 12:36:51 PM | 09' Rendering Issue
lunchtrayrider
3.5 Stars: 7 Votes
is the camera really close to a wall or in something?  (long shot i know)
Wed, Jun 3, 2009 at 12:44:14 PM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
Nope, Off to the site of the building I created a test building pretty much.
It is a big rectangle with a floor and ceiling w/lights. I rendering with a ceiling at 10' and its fine at 12' it doesnt work. It seems like there is something just cutting my rendering at a certain height
Wed, Jun 3, 2009 at 12:50:29 PM | 09' Rendering Issue
robertsheeley
4 Stars: 1 Votes
So i just did a test rendering on the exterior of the building to see if it would still chop the rendering at a certain height and it didnt. The exterior rendered fine. Attached is a 3d view, section box rendering and you can see where the black is.
Wed, Jun 3, 2009 at 3:16:50 PM | 09' Rendering Issue
#11
lunchtrayrider
3.5 Stars: 7 Votes
well i for one am interested to find out what is going on.  I'd be willing to look at the file if you posted it.  but either way good luck.
Wed, Jun 3, 2009 at 4:22:51 PM | 09' Rendering Issue
#12
If you posted a modified file ... four walls/slab & ceiling winth lights all cut down to just the one room then purged of everythin else, the file might be small enough for someone to look at it.
rendering issue
Mon, May 21, 2007 at 1:39:08 PM
Rendering with 'Radiate'
Mon, Aug 4, 2008 at 1:29:20 PM
Rendering Issue
Wed, Nov 30, 2011 at 10:21:49 AM
issue with rendering
Tue, Nov 24, 2009 at 6:18:48 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Page generation time: 1.5587
