Forums >> Revit Building >> Technical Support >> Beams that are copied are invisible, while beams placed can be seen??
Thu, Jul 21, 2005 at 5:04:20 PM | Beams that are copied are invisible, while beams placed can be seen??
Ace001
I've got an issue where beams/joists in my structure that are copied from an original are invisible, while beams that are placed one by one can be seen?? Anyone else have this problem? I'm using RevitBuilding8. I set one beam then did and array of 40 copies of that beam in section view, and they can't be seen in plan, only section!! What can I do other than do them one by one? Thanks
Thu, Jul 21, 2005 at 8:06:38 PM | RE: Beams that are copied are invisible, while beams placed can be seen??
eldados
eldados Avatar
4.5 Stars: 8 Votes
make sure your refrence level and work plane are set to your level... go to the properties of the beam
Fri, Jan 19, 2007 at 11:26:25 AM | Beams that are copied are invisible, while beams placed can be seen??
TesterSH
I see this is an old thread but I too am having issues with my beams only being visible in the elevation or section view, not in the 3D isometric view.  I have checked to ensure they were referenced to the correct level but still nothing is visible.  Any suggestions?
Fri, Jan 19, 2007 at 12:22:33 PM | Beams that are copied are invisible, while beams placed can be seen??
MrBob
3 Stars: 2 Votes
Try looking at the phasing of the copied objects.  Some times I noticed when things weren't showing up the phase was set to project completion.
Fri, Jan 19, 2007 at 12:37:08 PM | Beams that are copied are invisible, while beams placed can be seen??
TesterSH
Thank-you, I knew it was something simple...  I thought I had gone over everything but obviously didn't think to look there.  What an odd thing for REVIT to do.
Sat, Jan 20, 2007 at 9:53:43 AM | Beams that are copied are invisible, while beams placed can be seen??
TomDorner
4.5 Stars: 25 Votes
This Revit behaviour is not 'odd' but very predictable.  Any Revit object that is pasted into a view will take on the phase that view is set to.  If you copy objects out of a view with a phase of 'existing' and paste them into a view with a phase of 'new construction' the pasted items will have the phase value of 'new construction'.
Setting up multiple views of the project each with the approriate phase and pasting objects into a correct view will alleaviate your frustration.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Beams
Tue, Nov 15, 2005 at 3:41:26 PM
RVT2015 - Insert steel beams over doorway
Tue, Apr 25, 2017 at 9:06:47 PM
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:50 PM
Wooden Beams, beams beams.
Wed, Jul 15, 2009 at 12:20:06 PM
Beams connecting in frane family
Thu, Feb 15, 2018 at 3:53:08 PM
Page generation time: 0.1011
