Forums >> Revit Building >> Technical Support >> Revit 2008 wall mounted family placement issue
Tue, Jun 2, 2009 at 12:13:58 PM | Revit 2008 wall mounted family placement issue
pgrimmi
hi folks:
trying to create a wall mounted famuily with nested families. everything seems to be going well except that when i place the family in my model it buries into the existing 12 inch wall (see "wall mount 1.jpg"Winking. i know that it has something to do with the thickness of the wall in the family editor (see "wall mount 2.jpg"Winking. i could just make the wall in the editor the same as the wall in the model, but this family is going to be on different walls. i am sure that this is something simple that i am missing, could somebody point me in the right direction? thanks!
pgrimmi
Tue, Jun 2, 2009 at 12:21:52 PM | Revit 2008 wall mounted family placement issue
tim123
4 Stars: 19 Votes
You need to constrain the family to the edge of the wall.  If the wall gets wider, the family will move with it.
Tue, Jun 2, 2009 at 1:00:26 PM | Revit 2008 wall mounted family placement issue
pgrimmi
pardon my ignorance, but how do i go aboout doing that?
Tue, Jun 2, 2009 at 1:20:38 PM | Revit 2008 wall mounted family placement issue
4 Stars: 205 Votes
Use the "Align" tool....
Tue, Jun 2, 2009 at 4:08:58 PM | Revit 2008 wall mounted family placement issue
lunchtrayrider
3.5 Stars: 7 Votes
and then lock. or create dimensions that are locked.
Tue, Jun 2, 2009 at 5:29:42 PM | Revit 2008 wall mounted family placement issue
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Did you use the center of the wall in the editor to begin your modeling or did you create a new work plane which would be located on the surface of the wall. You might have to add parameters to establish the surface work plane with respect to the centerline of the wall.
Sun, Jun 19, 2011 at 2:34:12 PM | Revit 2008 wall mounted family placement issue
ivanthagr8
I have the same problem and can't figure out how to align the family to the face of the wall instead of the center. Can anyone please help me.
Mon, Jun 20, 2011 at 3:19:51 AM | Revit 2008 wall mounted family placement issue
4 Stars: 205 Votes
Use the "TAB" key, check that with your HELP menu.
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:37 PM
Compenent Placement - Issue
Thu, Mar 3, 2011 at 1:12:04 PM
Changing family from wall mounted to ceiling mounted
Mon, Nov 16, 2009 at 2:19:09 PM
Need help with family categories!!!!!!
Wed, Dec 3, 2008 at 8:43:09 PM
Make annotation on wall-mounted family show on floorplan
Wed, Nov 12, 2008 at 1:41:40 PM
Page generation time: 2.9392
