Forums >> Revit Building >> Technical Support >> Solid sweep
Mon, Jun 1, 2009 at 5:27:48 PM | Solid sweep
diesellam
Hi,
I just did a simple solid sweep of a med gas pipe on the same elevation.  (The sweep path is a "S" shape, the sweep profile is a simple circle.)
The question is:
What's the quickest way to make part of this sweep to be at different elevation?
Can Revit do something like adding points to the path and stretch the points up and down before the sweep?
Thanks in advance.
Wed, Jun 3, 2009 at 8:22:41 AM | Solid sweep
travistlo
5 Stars: 2 Votes
Revits modeling is all about workplanes. Think of them as your paper. You always draw onto the paper, so you need to get that workplane rotated properly. You can also use faces of objects as a workplane too.
Chatting it up on gmail - travistlo.j@gmail.com
Solid Sweep and doors?
Thu, Apr 27, 2006 at 10:59:11 PM
Cutting Solid Sweep?
Sun, Apr 23, 2006 at 11:03:51 AM
Material surface pattern on a solid sweep?
Wed, Nov 17, 2010 at 2:48:49 PM
Solid Sweep Creation
Wed, Sep 13, 2006 at 2:13:21 PM
Hatch to solid sweep
Fri, Mar 30, 2007 at 2:00:19 AM
Page generation time: 0.3034
