Forums >> Revit Building >> Technical Support >> cannot fiure out how to make linear light fixure give off linear light
Mon, Jun 1, 2009 at 3:25:39 PM | cannot fiure out how to make linear light fixure give off linear light
greg1970
I've got a 28' light fixture that still acts like its a down light.  I've made sure the right lighting source is used and I make sure the emit from line length is as long as the fixture but there is still a hot spot in the middle of light on the wall.  How do you get it to be the same intensity down the length of the fixture?
Mon, Jun 1, 2009 at 3:37:27 PM | cannot fiure out how to make linear light fixure give off linear light
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I would not make a single 28' light, I would use multiple nested families or just multiple families to create the light. I have seen this in the forums before and it seems someone had a decent solution but i cant remember it.
Mon, Jun 1, 2009 at 3:44:06 PM | cannot fiure out how to make linear light fixure give off linear light
greg1970
I was hoping to reduce the number of lights so as to reduce the rendering time.  But I guess that will be a no go.
Tue, Jun 16, 2009 at 10:24:57 AM | cannot fiure out how to make linear light fixure give off linear light
NYHokie84
I found that rendering on settings above Low will eliminate the hotspot efect where on low and draft rendering settings there is a hotspot centered on the linear light source no matter how long or how many lights there are.
Linear lights aren't linear at all?
Fri, Feb 4, 2011 at 1:54:01 PM
Recessed linear light
Tue, Feb 3, 2009 at 1:48:45 PM
Linear Lighting
Wed, Dec 27, 2006 at 2:58:38 PM
Linear lighting fixture
Wed, Sep 2, 2009 at 2:32:08 AM
Linear lights rendered as spot lights
Thu, Dec 29, 2016 at 7:18:38 AM
Page generation time: 1.6264
