Forums >> Revit Structure >> Technical Support >> Nested Curtain Wall Panels
Mon, Jun 1, 2009 at 9:19:15 AM | Nested Curtain Wall Panels
nelssimpp
I am currently working on a steel panel system for steel building structures. The wall and ceiling panels are insulated and therefore are comprised of an inside-skin, outside-skin and an insulation core.From researching the AUGI forums I understand the approach to take is to create the panels as a curtain wall family. That way they can be used to replace the infill panels in a standard curtain wall system.I have been successful in bring the panels in as individual components (inside-skin, outside-skin, or insulation core) to replace infill curtain wall panels. However, I am having difficulty when it comes to replacement of the standard infill panels with the combined panels (inside-skin, outside-skin, and insulation core) as a “Nested Curtain Wall” infill replacement panel.Can ‘Nested Panels’ be used as a curtain wall panels?Is anyone aware of how to go about this or do you have any suggestions for creating a layered or nested panel system?
Thu, May 28, 2009 at 2:33:52 PM
HOW TO SCHEDULE NESTED CURTAIN PANELS
Thu, Jul 9, 2009 at 3:51:32 AM
Need Help Aligning /Locking Nested Components to Host Curtain Wall Panel
Fri, Sep 4, 2009 at 9:57:10 AM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Page generation time: 1.3120
