Forums >> General Discussion >> Revit Project Management >> printing too light and single pen
Mon, Jun 1, 2009 at 7:29:37 AM | printing too light and single pen
annies91484
ok, i will try to explain this as well as i can.  i am printing to a kipp from revit.  in our project template, the line weights are set up properly, or so i think.  when i print, everything is very light and looks to be single pen.  except you get the occasional way too bold line not where it is needed.  i don't know how printing in revit works.  I know in CAD we have ctb files set up to properly print line weights.  anyone provide help with revit printing?  how i can properly display and print line weights.
thanks!
Mon, Jun 1, 2009 at 7:49:06 AM | printing too light and single pen
All of your lineweights are established in Revit's Settings/Lineweights chart and which of the 16 pens (or more) you have assigned to your categories.  Beyond that, printing problems are usually a fuction of your printer and drivers.  Have you loaded the latest drivers?
If you do a search of the revit forum useing " kip ", you will find several posts of others who have problems with this printer.
drafting views pen weights light with linked .dwg
Fri, Nov 6, 2009 at 12:58:02 PM
2 in 1 laptops 17" with active pen available?
Wed, Oct 30, 2019 at 5:44:19 PM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
pen tables
Tue, Jul 22, 2008 at 4:10:40 PM
Reveals and pen weights?
Thu, Oct 26, 2006 at 10:14:48 AM
Page generation time: 0.1788
