Forums >> Revit Building >> Technical Support >> Revit 2010 Dwg. Import problem
Mon, Jun 1, 2009 at 2:00:40 AM | Revit 2010 Dwg. Import problem
Fluffyfatcat
3.5 Stars: 3 Votes
I wonder if someone have similar problem importing Cad drawing.
I have Land Survey in Cad with 3d points, it fails to import to Revit 2010-have a message that REVIT can't import, because it will create Revit model that is larger than 2 miles accross...etc etc.
I have tied to import few different projects surveys and none of my sites are larger than 2 miles. I have no problem with importing them in Revit 2009-the message is  that some numerical data is trancated and it imports without a problem.
I tried to delete all my layers in cad xcept levels and import-no luck, I moved UCS as a surveyer's dwg was to MGA grid  0,0,0 -no luck, I can't think of anything else. Is there a bug?
Thanks
Mon, Jun 1, 2009 at 5:14:27 AM | Revit 2010 Dwg. Import problem
tim123
4 Stars: 19 Votes
There have been a few threads on this subject.  Try the following:
Reduce the physical size of the CAD drawing to that required for the site - zoom into the drawing to ensure that there are no objects far from the origin.
Move the UCS to the centre of the drawing.  It would appear that you only need this for the toposurface, so you won't need to co-ordinate it with the cad drawing.
Mon, Jun 1, 2009 at 11:37:48 PM | Revit 2010 Dwg. Import problem
Fluffyfatcat
3.5 Stars: 3 Votes
thanks Tim
Tried all suggested above earlier same result, unfortunately I can't move UCS to the center as i use few cad drawings attached with origin point usually datum or corner of the site. So at the moment i am importing my Cad drawings into 2009 to build topo...not good enough....also find the transition to a new interface painful (just a whimper..)
Tue, Jun 2, 2009 at 6:01:48 PM | Revit 2010 Dwg. Import problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Is the surveyor's drawing really in inches which Revit sees as feet.
Wed, Jun 3, 2009 at 6:36:54 PM | Revit 2010 Dwg. Import problem
Fluffyfatcat
3.5 Stars: 3 Votes
Surveyors drawing comes in meters, I scaled it up x1000 to convert it in mm. and set units to millimeters
so it was imported in mm. (I tried both automatic unit detection and mm. setting in Revit). Actually I managed to import one Survey when I deleted Cad layer with Cad 3D triangulations, it did not help other Surveys though. I tried to W-block Cad Survey, trying to get rid of junk it may have, but no success.
Thu, Jun 4, 2009 at 10:19:47 AM | Revit 2010 Dwg. Import problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
when I import the entire drawing, but when a use make topo surface I only want the contour line usually major and minor.
Thu, Jun 4, 2009 at 10:24:35 AM | Revit 2010 Dwg. Import problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
the major and minor contour lines should be selectable boxes during the create toposurface from Imported 3D data, when the dialog box opens I select only the major and minor contour lines.
Hope this helps,
Steve
Thu, Sep 2, 2010 at 12:53:21 AM | Revit 2010 Dwg. Import problem
mudan
i have a problem that when i import the dwg. its sit on top of my building even though i select the ground level threrefore when i create my topsurface by using import file its all 9m plum above. anyone can help me please.
Thu, Sep 2, 2010 at 1:16:20 AM | mudan
Fluffyfatcat
3.5 Stars: 3 Votes
Quoting mudan from 2010-09-02 00:53:21
When you import your Acad drg make sure that you have plan open at Datum (site level) @ 0.00 level, so if your Cad contours elevated, say 9m. above datum it'll place your topo at the right level or you can move your topo down (if it's already imported and modeled) to the right level relative to your floor level (you do it in elevation view) I hope I understood your Question correctly cheers
Thu, Sep 2, 2010 at 1:52:03 AM | Revit 2010 Dwg. Import problem
mudan
thanks alot! didnt think i will get a reply that quick. i will have a try cheers
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
Import 3D .dwg model in Revit Architecture 2012
Tue, Oct 9, 2012 at 6:39:39 PM
.dwg import problem
Tue, Sep 6, 2011 at 7:48:54 AM
import dwg to revit but cant underlay
Sun, Apr 26, 2009 at 5:24:18 AM
Page generation time: 1.6689
