Forums >> Community >> Newbies >> Newbie: Wot no ref planes in Circular Handrail.rfa
Sat, May 30, 2009 at 6:10:21 PM | Newbie: Wot no ref planes in Circular Handrail.rfa
SemiDeatched
I'm a bit confused how some parameterised profiles work...
If I open Circular Handrail.rfa I see a circle but no reference planes or dimensions... How does the relationship for the Type Parameter work?  There must be something going on since an attempt to delete the Type parameter states that is it used in 2 places;  I cannot see such places.
TIASD
Sun, May 31, 2009 at 6:10:27 PM | Newbie: Wot no ref planes in Circular Handrail.rfa
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
many of the stock families have the reference planes and dimensions turned off.  to turn them back on, open visibility graphics (VG or VV) and select the "Annotation Catigories" tab.  from there you can turn the ref planes and dim's on.
there are many posts regarding parameters.  i suggest you run a search here in the forum.  it sounds as if you may be trying to delete a type of a family, while instances of that type still exist in your drawing.
Revit 2010 - It's a good thing... Stop Fighting it.
Mon, Jun 1, 2009 at 4:26:00 PM | Newbie: Wot no ref planes in Circular Handrail.rfa
SemiDeatched
Thanks.  That was the problem.  did VG, and turned on AnnotationCategories, and I can now see the Ref Planes and constraints.
 RegardsSD
Circular handrail on curved stair
Mon, Jan 7, 2013 at 8:23:25 AM
Wish List - Toggle Reference Planes
Fri, Sep 24, 2010 at 1:23:59 PM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:53 AM
how to change defined ref planes in a family
Mon, Apr 18, 2011 at 2:07:00 AM
How Can I Change The Dimensions Of A Window To A Specific Custom Size?
Tue, May 26, 2009 at 7:28:02 AM
Page generation time: 5.9948
