Forums >> Revit Building >> Technical Support >> area plan from duplicated floor plan
Sat, May 30, 2009 at 5:53:00 AM | area plan from duplicated floor plan
emosms
HI
-i have been working on a fire plan, with fire escape routes and colored walls by fire rating
-the fire plan is a duplicated view of a floor plan (independent)
-i created new area plan type - fire compartments
-then i wanted to create an area plan from the fire plan floor plan view, but i cannot select it as an option
-this is needed to color schedule the fire compartments in the building (2,3,4 rooms - up to 150m2 for a compartment)
-i dont want to start over on doing my fire plan as an area plan
RAC 2009
Best Regards
Wed, Jun 3, 2009 at 8:12:34 AM | area plan from duplicated floor plan
travistlo
5 Stars: 2 Votes
When you create area plans, you have to select a level, not a view. So this is why you cannot start off with the fire plan.
 Just make your new area plan. copy and paste all the Detail items, then apply view template, and choose the old fire plan and the template. This should get you to the same point with not a lot of extra work.
Chatting it up on gmail - travistlo.j@gmail.com
Wed, Jun 3, 2009 at 8:38:26 AM | area plan from duplicated floor plan
emosms
yes, this is it. I got it afterwards and did some more work...
Smile
Area from Area plan to show on floor plan
Fri, Feb 27, 2009 at 7:53:29 PM
Area Plans.....
Thu, Jun 22, 2006 at 5:31:08 PM
Use Area Plan as my Floor Plan?
Fri, Aug 30, 2019 at 12:31:02 PM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Plan Range - displayingn duplicated views
Wed, Aug 1, 2007 at 8:45:02 AM
Page generation time: 4.4402
