22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> CAN'T SEE...
28 Posts No Rating |
I am unable to see my timber beams in a structural framing plan. I have checked the view properties and view range and everything is set to what it should be. This is not just occuring on one level but multiple. Does anyone have any ideas why the beams are not visible?
Did you try to change the "Coarse" mode to "Fine" mode???
This did not work. I must also say that if I try to place a structural beam in the plan it does not show. Does anyone else have any suggestions?
have you verified their elevation by cutting a section?
After my last post I did this and was able to solve my issue. Thanks.
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
'Out of Memory' pop up |
Tue, Sep 6, 2005 at 3:16:07 PM
Sheet # of 'total number of sheets' |
Fri, Nov 16, 2007 at 6:59:54 AM
When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e |
Fri, Jun 11, 2021 at 7:44:53 AM
