Forums >> Revit Building >> Technical Support >> Problems with adding text to dimension lines.
Thu, May 28, 2009 at 4:44:21 PM | Problems with adding text to dimension lines.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Revit 2009:
I attempted to add text before, after, & under various dimensions on a long string.  They kept disappearing on me.  I would add text to the last dimension in the string and find the first text no longer visible.  When I tried to edit the witness lines and add additional dimensions, all of the text, previously entered, disappeared.  Am I doing something wrong or is it just Revit being wierd again?
Thu, May 28, 2009 at 5:28:10 PM | Problems with adding text to dimension lines.
wheelergc
Is you annontation crop on? That will make tet disappear.  But is does usually give you a warning.
Thu, May 28, 2009 at 5:47:17 PM | Problems with adding text to dimension lines.
jarosa
jarosa Avatar
4 Stars: 5 Votes
Revit is being inconsiderate. If you edit the witness lines you will lose the text. I think it's because it recalculates the dimensions. Why it loses the text......????
lol
Fri, May 29, 2009 at 7:52:03 AM | Problems with adding text to dimension lines.
I just checked mine out in 2010 and don't have that happening.
Fri, May 29, 2009 at 8:48:43 AM | Problems with adding text to dimension lines.
travistlo
5 Stars: 2 Votes
in 2009, if you override the text, then change the dimension (like adding a witness line, or removing one) revit will ALWAY remove your overrides.
Sometimes, I find it easier to break that string up into multiples if the override is very very important, this way there is no accidents.
Chatting it up on gmail - travistlo.j@gmail.com
Sat, May 30, 2009 at 6:28:49 PM | WWHub
jarosa
jarosa Avatar
4 Stars: 5 Votes
Quoting WWHub from 2009-05-29 07:52:03
"I just checked mine out in 2010 and don't have that happening."
I'll have to check that out. I find it amazing that the factory would fix a problem and not market it.
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
DIMENSION TEXT
Tue, Jun 5, 2012 at 10:17:41 AM
Detail Custom Text Change
Thu, Oct 23, 2008 at 11:59:06 AM
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Page generation time: 0.9293
