Forums >> Revit Building >> Technical Support >> Curve Approximation Quality
Wed, Jul 20, 2005 at 2:31:28 PM | Curve Approximation Quality
JoeDrevitO
Does anyone know how to change the settings in revit for how well a cuve is approximated. If I try to get a close up view of some small detail that uses an arc or circle (splines dont seem to be affected) I can see that the arc is approximated by several straight lines. I would like to make it so more lines are shown to give it a better view. Cheers!
Wed, Jul 20, 2005 at 6:04:05 PM | RE: Curve Approximation Quality
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not possible, This is built into the system properties of revit to which we don't have access to. This should only occur on solids though... Model/Detail lines should all appear natural...?
Logo Placement in Curve Shapes
Wed, May 2, 2012 at 9:08:20 PM
walkthrough file in bad quality
Sun, Jul 11, 2010 at 1:27:52 PM
Curve Walls
Mon, Dec 22, 2008 at 6:13:27 PM
Font Quality
Wed, May 11, 2022 at 10:38:16 AM
Making Curve Ladder Trusses
Tue, Jan 16, 2018 at 8:21:53 AM
Page generation time: 0.0503
