Forums >> Revit Structure >> Technical Support >> Joining Columns??
Thu, May 28, 2009 at 3:08:46 PM | Joining Columns??
gemuser
I would like to know how to join a column to the base plate, column cap plate, a shear tab connection or similar families that are inserted into the project.  In the current project, I had to shift some grids and the columns shifted just fine but it left the base plates in their previous position.  Any tips?
Thu, May 28, 2009 at 3:18:19 PM | Joining Columns??
4 Stars: 205 Votes
Images please from your issue....
Thu, May 28, 2009 at 3:47:12 PM | Joining Columns??
lunchtrayrider
3.5 Stars: 7 Votes
You could align and lock the parts to the grids.  You could insert reference planes in the familiy that would give you something to lock to the grids.  honestly it is probably easier to just move them.
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:51 AM
joining two round columns together
Tue, Jul 16, 2013 at 6:28:05 AM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
Can't select beams nor columns
Sun, Mar 10, 2019 at 10:12:36 PM
Joining sloped rafters to columns.
Thu, Mar 17, 2011 at 5:27:16 PM
Page generation time: 0.0853
