Forums >> Revit Building >> Technical Support >> How to show lighting fixtures on floor plan
Wed, Jul 20, 2005 at 1:36:50 PM | How to show lighting fixtures on floor plan?
MsLx
Hi, I'm a lighting consultant using revit to draw lighting desing layouts onto house plans. I use arcs to connect the fixtures to the wall switches. I need to see the floor plan, the lighting fixtures, the electrical fixtures and the lines in plan mode. Sometimes it works and sometimes it doesn't, any ideas? I've tried all sorts of visibility combinations, to no avail. I would appreciate any information that could further me in this process. Thanks Post edited on 2005-07-20 13:37:49
Wed, Jul 20, 2005 at 1:55:29 PM | RE: How to show lighting fixtures on floor plan
arnosandoval
5 Stars: 3 Votes
Are you using Drafting lines, those are good to use for drafting on 2D plans, etc. Lights can be viewed in a reflected ceiling plan, I don't know if you want to view the fixtures in plan or in RCP mode. Hopefully this shed some light to your problem. If you send a jgp of your problem then I can better answer your question.
Wed, Jul 20, 2005 at 6:01:43 PM | RE: How to show lighting fixtures on floor plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To show the lighting fixtures in plan... One method is to edit the lighting families and add an invisible model line that runs from the lighting fixture to the ground. Due to the visibility of the lighting fixtures, if any of it is cut, the whole element displays. So in plan your cut plane would then cut the invisible line and your lighting fixture should display. HTH.
Fri, Jul 22, 2005 at 9:12:09 AM | RE: How to show lighting fixtures on floor plan
MsLx
Thanks for your input, I really appreciate it. I've attached two drawings of a recent job. Combined, I get all the elements I'm looking for, but I can't seem to get them on the same view. The L shaped rectangles represent the bar and the three circles represent light fixtures. Thanks again I'll attach the next one on the next reply.
Fri, Jul 22, 2005 at 9:13:08 AM | RE: How to show lighting fixtures on floor plan
MsLx
Here is the next image. I'll also try cutting the family. Thanks
Fri, Jul 22, 2005 at 6:12:43 PM | RE: How to show lighting fixtures on floor plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The other option and perhaps easiest is to just drag the two views over the top of each other on the sheet. (floor plan & RCP with the elements of each visible that you want to see) They'll snap into place automatically.
Thu, Aug 4, 2005 at 1:29:09 PM | RE: How to show lighting fixtures on floor plan
johnfire
How do they "snap' to each other automatically? Also when you are in a RFC plan how do you put in light fixtures? It says to pick a ceiling but it doesnt place the fixture when I try to put one in. Post edited on 2005-08-04 15:15:08
Mon, Nov 6, 2006 at 10:15:38 PM | How to show lighting fixtures on floor plan
bbrown
3 Stars: 1 Votes
As you drag the ceiling view over the floor view, there will be a vertical green line and a horizontal green line...when you see both...CLICK. It works great!
Floor plan showing ceiling fixtures and wiring to switches
Wed, Feb 18, 2009 at 2:49:44 AM
how to do electric and lighting plans
Thu, Jan 7, 2010 at 11:59:17 AM
Revit MEP 2010 copy/paste lighting fixtures
Sun, Feb 16, 2014 at 12:46:34 AM
The lighting fixtures wont show up in my final revit 2013 rendering.
Wed, Jul 31, 2013 at 3:23:18 AM
create a new lighting fixtures
Fri, Aug 15, 2008 at 10:54:54 AM
Page generation time: 1.9715
