37 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> IFC export: Gross Area
26 Posts No Rating |
We have to export an IFC model for a competition. One of the requirements is IfcSpace objects for both nett and gross area. I seem to export RvtRooms OK but not RvtAreas. The work around at the moment is a room for gross area 'off site'. Is there a better way?
Set up an area plan Room & Area tab - (NOT ROOMS!) and set it up under settings.
Even if I change the export settings so RvtArea goes to IfcSpace this does not seem to work (now). In that wonderful revit way it did work for a while  no idea why it has not worked since) but the names of the gross areas were 'xx GSA Design Gross Area' where xx is the level. The competition software wants them to be 99.0xx (IfcSpace zone 99 level xx) I can do this with rooms but changing the RvtArea name/number seems to make no difference to the IfcSpace name. By the way the competition software only accepts IfcWalls, doors windows and slabs. Is there any easy way to convert eg curtain walls into an acceptable object?
Rentable vs Gross area, gross area in practice |
Tue, Mar 13, 2012 at 11:15:27 AM
Revit MEP IFC Export - Objects not detalied |
Wed, Jul 2, 2014 at 8:08:29 AM
Gross areas & Phasing |
Mon, Feb 23, 2015 at 9:14:01 AM
Gross, Rentable, and Usable Floor Area |
Mon, Jul 12, 2010 at 9:05:26 AM
Revit Family Export to IFC |
Fri, Nov 29, 2013 at 4:29:41 PM
