Forums >> General Discussion >> Revit Project Management >> COLOR SCHEME IN SITE PLAN
Wed, May 27, 2009 at 4:55:54 PM | COLOR SCHEME IN SITE PLAN
jgmas
I know how to create a color scheme in floor plan views, but can you create a color scheme in the site plan view??
 I tried and did not have any luck, also can you show the room tag in the site plan view? I also tried doing that, and again di not have any luck.
Thanks for all the help
Fri, May 29, 2009 at 8:51:17 AM | COLOR SCHEME IN SITE PLAN
travistlo
5 Stars: 2 Votes
A view is a view, they all behave the same way. The only differnce is what the settings are. Compare the settings, and see if you can get it to work properly (dont forget to change the scale as well in your attempt to figure it out)
Chatting it up on gmail - travistlo.j@gmail.com
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
PNG- TRANSPARENCY- COLOR SCHEME
Sun, Sep 30, 2018 at 10:09:50 PM
Color Scheme in Reflected Ceiling Plans?
Thu, Nov 20, 2014 at 10:16:01 AM
Area Plan Color Scheme Cannot be changed???
Thu, Sep 11, 2014 at 11:58:37 AM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Page generation time: 1.0803
