Forums >> Revit Building >> Technical Support >> copy curtain wall into different wall?
Wed, May 27, 2009 at 2:10:20 PM | copy curtain wall into different wall?
ejm159
hello
I'm trying to figure out how to copy my curtain wall from one wall into another.  It is also gouped.  I have probibly 20 instances of that curtain wall in one wall and i'd like to copy it into other exterior walls. am i screwed?  Using revit 2008.  Thanks in advance for your helpSmile
-eric
Wed, May 27, 2009 at 2:53:17 PM | copy curtain wall into different wall?
First question - why is it grouped.  Groups are very special and you use them when you want to place same groupings elsewhere.  I doubt that is what you have.
OK - Just tab and select your curtain wall - it doesn't matter if it's in the group, it will be selected seperately.  Copy to clipboard and paste of just copy and place.
Wed, May 27, 2009 at 3:20:33 PM | copy curtain wall into different wall?
ejm159
Thanks whub.  that worked great.  I was trying the copy command on the tool bar...
I grouped the curtain wall so i could edit it and all instance would update.  Would you sugets i do it different?  Make a family?
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
deleting curtain system once it is in place
Wed, Dec 3, 2008 at 8:48:26 AM
Cannot figure out how to copy a wall section up to next story?
Sun, Oct 13, 2013 at 7:57:01 AM
Wall hosted family can't be hosted on curtain wall?!
Fri, Oct 22, 2010 at 7:13:04 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Page generation time: 1.4779
