Forums >> General Discussion >> Revit Project Management >> Uploading Fonts
Wed, May 27, 2009 at 10:32:34 AM | Uploading Fonts
denisemarie26
denisemarie26 Avatar
How do you upload architectural font into Revit?
Why isn't it offered with Revit?
Can all of the existing font on the drawing be changed over once new font is uploaded?
Wed, May 27, 2009 at 10:49:15 AM | Uploading Fonts
There are several posts on this in the forums if you just search them.  REVIT uses the windows system TTF fonts.  Anything loaded there can be used but AutoCAD's SHX files are NOT TTF so you can not use those.
You can change a text definition to any TTF font that is loaded in windows.
Thu, May 28, 2009 at 11:30:20 AM | Uploading Fonts
denisemarie26
found it in help
To map TrueType fonts
  1. Open the shxfontmap.txt file in a text editor.
    This file resides in the Data folder of the Revit Architecture installation directory.
  2. On a new line, enter the SHX file name.
  3. Press Tab.
  4. Enter the name of the font you want to map it to.
  5. Save and close the file.
You do not need to restart Revit Architecture for the font mapping to take effect. If you have already imported the file, you will need to import it again.
Thu, May 28, 2009 at 11:33:56 AM | Uploading Fonts
This does not put this font style in REVIT - it simply maps what font in REVIT you want to use as a substitute for a dwg file that you are importing.
Thu, May 28, 2009 at 3:56:15 PM | Uploading Fonts
jarosa
jarosa Avatar
4 Stars: 5 Votes
Pretty simple to do. Find the font you want. I use ARchitxt. Go to C: Windows/Fonts. Copy and paste your font to this file location and it will be available when you modify your text and dimensions.
Good Luck
John
Tue, Jun 16, 2009 at 4:24:41 PM | Uploading Fonts
denisemarie26
Thank you, worked perfectly.
Fonts For Revit
Mon, Oct 8, 2007 at 8:19:03 AM
fonts
Thu, Feb 24, 2011 at 2:57:05 PM
Uploading components
Wed, Dec 10, 2008 at 10:53:38 AM
FONTS!
Thu, May 4, 2006 at 2:46:59 PM
Archival Fonts?
Thu, May 19, 2016 at 6:32:24 AM
Page generation time: 0.0330
