18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> RAC 2009 - Text in CAD file is not plotting?
Hello - We have some typical details that are set-up as cad drawings, which are then referenced in our Revit model. For some reason the text is not plotting in all the view when we create pdfs. It is only the text which is not printing, and does not seem to be consistent - ie some details are fine and others are missing text. Any ideas what might be going wrong here? Thanks!
does the same thing happen if you dont print to the pdf? (send it to a plotter or laser printer)
----------------------------------- Chatting it up on gmail - travistlo.j@gmail.com |
Hi - yes we tried printing to different plotters and the results were consistent - in some of the detail views, text does not print.
Did you check the color / pen size of the imported layer? Settings/object style / imported objects Did you know that you can set it to white and in essence make it a no-plot ?... but then you can't see it in the view either. You might try upping the line size for the text layer and see what happens.
export cad text file BS1192 |
Wed, Jul 22, 2009 at 6:56:46 AM
Room Separation Lines not plotting properly RAC 2009 |
Thu, Aug 6, 2009 at 5:47:46 PM
Problem exporting view with linked CAD file |
Wed, Mar 18, 2009 at 3:46:34 PM
Linking CAD file with GEO Marker - RAC 2010 |
Wed, Sep 23, 2009 at 4:58:21 PM
RAC 2009 - Linked CAD file in Ceiling Plan View |
Wed, Jul 15, 2009 at 12:53:08 PM
