Forums >> Revit Building >> Tips & Tricks >> Achieving Joints between two walls
Wed, May 27, 2009 at 5:33:05 AM | Achieving Joints between two walls
andrewjossf1
I am trying to draw a concrete wall panel system that has a joint similar to the joint shown in the attached image  (Panel joint.jpg) at either end. I am struggling to find the best way of achieving this.
The worst case scenario would be just to have a simple 10mm joint between panels. I have tried to do this with the standard revit wall but it keeps trying to join the walls together.
 Any suggestions would be appreciated.
 Thanks in advance
Andrew
Wed, May 27, 2009 at 5:40:30 AM | Achieving Joints between two walls
4 Stars: 205 Votes
I think i create that with "Curtain walls", create the curtain wall panel in a family then load to project and change the panel by the new family....
Fri, May 29, 2009 at 12:55:22 PM | Achieving Joints between two walls
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Have you tried right clicking on the little end point circle and hitting disallow join?
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Jun 9, 2009 at 7:40:51 AM | Achieving Joints between two walls
MARS1276
1 Stars: 1 Votes
This looks like a job for... not Superman.  I have found the 'Edit wall profile' to be useful.  My thoughts on this one would be to create a wall, edit the profile for the end, then mirror the wall about an axis line which you draw to define.  If you need this throughout, you would have to copy each wall and move them (probably).  In any case, this seems to be an interesting problem and I would love to hear what you actually find works best.  Have you tried applying an image to the face of a simple wall to make it appear as you want it to?
do walls join differently in ceiling plans for you?
Thu, May 5, 2011 at 11:30:02 AM
12
vertical joints in hosted wall sweep?
Mon, Aug 13, 2007 at 3:37:15 PM
Concrete control joints
Thu, Mar 31, 2016 at 1:52:27 PM
11
Problems with offset joints in tilt-up concrete walls
Fri, Jul 1, 2011 at 11:01:16 AM
Control Joints
Mon, May 29, 2006 at 6:10:23 PM
Page generation time: 0.9493
