10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> commands....
I was wondering if there is a command in Revit that is similar to the "stretch" command in AutoCAD. Say I have a bunch of detail lines all side by side and wanted to stretch them all to a certain point, is that possible, or do you have to click on them one by one and do it that way? I am using Revit MEP 2009. Thanks!
if all the ends are the same you can draw a line down the ends points (1 line) and move the newly created line. The other existing lines should stretch with the perpindicular line. Then delete the line.
----------------------------------- Chatting it up on gmail - travistlo.j@gmail.com |
There isn't a "Stretch command" or "Extend/trim by fence" like in Autocad if this is what you mean, Travistlo give you a workaround IF, just like he said, ALL lines have the endpoints align at the same axis, but if they are disagreements you must extend/trim them one by one....
Why doesn't reivt have the simple autocad commands that we know and love. [ 1 2 ] |
Thu, May 7, 2009 at 1:22:38 PM
15
I wish Revit had the same drawing commands available as AutoCAD!! |
Sat, Feb 17, 2007 at 6:32:46 PM
Use REVIT Shortcut Commands |
Wed, Mar 31, 2021 at 7:59:28 AM
Where are *blend, sweep...* commands in Massing & Site |
Sat, Mar 27, 2010 at 8:45:29 AM
Command bar multiplies during commands |
Fri, Aug 19, 2011 at 1:21:57 PM
