Forums >> Revit Building >> Technical Support >> Controlling Wall Paths
Tue, May 26, 2009 at 9:46:50 AM | Controlling Wall Paths
architimmy
I am working on Revit 2009 and am having an issue getting a wall to close correctly. I have a particular wall edge I want to define but it has acute and 90 degree angles which happen within the thickness of the wall. This seems to result in the wall continually being closed in a way that makes no sense. I have attached two images. One shows the desired wall edge before I close the wall and the second shows the resulting wall after connecting all the walls together.
Tue, May 26, 2009 at 9:53:59 AM | Controlling Wall Paths
travistlo
5 Stars: 2 Votes
Pick one of the walls. There should be a blue dot on the end of it. Right click on the dot and choose disallow join. This gives you more control for the joining of wall intersections. Once you have the walls in the correct places, use the join geometry command to get them to graphically looks nice.
Chatting it up on gmail - travistlo.j@gmail.com
Tue, May 26, 2009 at 10:04:43 AM | Controlling Wall Paths
architimmy
Thanks!
After a bit of experiementation I was able to use this method to get a cleaner looking join at the wall. I can handle a few extra lines, what was most important was to get the wall perimeter correct!
Tue, May 26, 2009 at 10:13:17 AM | Controlling Wall Paths
architimmy
In case anyone comes across this I used the disallow join command along with locking dimensions to acheive the desired results.
Tue, May 26, 2009 at 11:06:37 AM | Controlling Wall Paths
travistlo
5 Stars: 2 Votes
FYI when joining geometry, the order of selection matters. Experiment with choosing 1 wall before another and see how that works.
additional rendering paths
Mon, Apr 13, 2009 at 2:13:42 AM
Controlling Line Weights with Filters
Tue, Dec 10, 2013 at 11:53:50 AM
Revit 2009 - Additional Render Appearance Paths
Tue, Sep 2, 2008 at 7:44:11 AM
controlling curtain wall embedment
Mon, Jan 25, 2010 at 2:36:58 PM
Openings--how do you control constraints?
Thu, Jun 11, 2009 at 1:51:27 PM
Page generation time: 3.3294
