Forums >> Revit Building >> Technical Support >> Aligning A Schedule
Tue, May 26, 2009 at 8:21:15 AM | Aligning A Schedule
chutton
Hello all,
 I haven't found a way, but hopefully someone can think of a workaround for the following problem.
I want to constrain a Schedule to a setposition on my Titlesheet, relative to it's borders, but there does not seem to be a way i can constrain this.Dimensions won't 'stick' to a schedule, i have also tried pinning the schedule within a group.
I want to effectively constraining a revision schedule to the top left of the Titlesheet as i flex a family for different paper sizes.
I do not want to place the revision box directly above the titleblock itself ( i know, it would be easier, it's just not corporate sorry! Winking
 Help would be appreciated.
 Ta much
Colin...
Tue, May 26, 2009 at 9:52:17 AM | Aligning A Schedule
We don't use parametric title sheets, we create different sheets for each size drawing.  That would seem to be an easier solution.
Tue, May 26, 2009 at 10:10:30 AM | Aligning A Schedule
chutton
Hi
Thanks for that, you're right, it would be an easier solution, but that's not really what i was asking, I am deliberately taking the more complicated route as i think it's potentially better in the long run.
Parametrically everything is fine, the revision boxes move when you flex the titlesheet family.
Here is the problem though  when you bring this family into a project, it leaves revision boxes for the different Sheet Sizes in the sheet view if you decide to change the Sheet Size.
For example  , if you start with an A1 sheet it creates the revision box in the correct location, if you then switch to A3, it leaves a revision box where the A1 revision box is, and also create a revision box for the A3 variant....rather strange...( Revit 2009 by the way )
I like the challenge, sometimes easy doesn't quite give the satisfaction...anyone else with any advice?
Tue, May 26, 2009 at 10:30:35 AM | Aligning A Schedule
coreed
coreed Avatar
4 Stars: 16 Votes
if it's not against your company policies, could you post an example?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 26, 2009 at 10:42:31 AM | Aligning A Schedule
chutton
Hi 'Coreed' , i have sent an email to your registered email address?
 Is this the correct address first of all? If so i would rather send direct rather than post on the forum?
Tue, May 26, 2009 at 11:05:55 AM | Aligning A Schedule
qabulin
qabulin Avatar
We make separate Titleblocks for every sheet size with the revision box already sized, set in place and ready to go.
All I have to do is load the sheet when it comes time.  In the end, I can live with the results thereof in consideration of the improved productivity.
Hopefully that would work for you as well.
qab
^_^
Debian + VirtualBox + Revit
Tue, May 26, 2009 at 12:55:54 PM | Aligning A Schedule
bert
A fortune cookie once gave me this fortune: "Impossible standards just make life difficult." I've taped it to my monitor, since this is especially true when those standards were set up for a different software...
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Tue, May 26, 2009 at 2:03:33 PM | Aligning A Schedule
lunchtrayrider
3.5 Stars: 7 Votes
+1 to bert on this.  As cool as this would be to get to work, qabulin's way is the only I know of.
Wed, May 27, 2009 at 3:02:29 AM | Aligning A Schedule
chutton
ALL,
 It's currently the only way I know of as well, and one that I currently adoby , so thanks! I'm sure we've all tried what i'm trying to achieve at one point, at least i'm not alone in my frustrations....
 and if anyone ( read Autodesk ! cracks it ,  then i hope they'll let me know..
 many thanks!
Wed, May 27, 2009 at 7:09:59 AM | Aligning A Schedule
MARS1276
1 Stars: 1 Votes
Now for a similar question: Does anyone have a nifty trick for lining up the Schedules so they are the same size and appear to be the same length?  So far the only way I have found to do this is to overlap the schedule beneath the other and just drag the arrows to adjust the columns to a similar width.  It would seem there should be an easier way; maybe a simpler way even.
Tips, anyone?
Wed, May 27, 2009 at 10:05:00 AM | Aligning A Schedule
qabulin
qabulin Avatar
Personally speaking, that's pretty much what I do.
It may seem like a nuisance, but so is last minute comments that dont fit in schedules... which the arrows are handy for.
I hated all the "dialing" and tweaking I had to do with the CAD schedules. ^_^
qab
^_^
Wed, May 27, 2009 at 10:55:07 AM | Aligning A Schedule
mars - what you are doing is what we all do I think.  After all - this is just a visual issue and this works and is simple.
Why does it have to be precise down to the 1/128 ?  I think that is just a CAD carry over thought process.
Thu, May 28, 2009 at 7:16:26 AM | Aligning A Schedule
#13
MARS1276
1 Stars: 1 Votes
OK, ok... I'll admit it.  I have used schedules in CAD and it was one of those "well if it can be done in CAD, why not Revit?" ideas.  It IS a good idea to go ahead and make schedules as part of the template page you load.  I'll have to see if my Drafting Senior will consider doing this.
Thanks for the response guys!
Aligning Grout Lines in Render Materials
Fri, Dec 16, 2011 at 6:47:21 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP!
Tue, Mar 11, 2008 at 1:25:09 AM
Fri, Sep 8, 2006 at 1:00:21 PM
Aligning Viewports on ALL SHEETS
Fri, Sep 8, 2006 at 12:58:13 PM
Adding / Aligning Legends to multiple sheets
Fri, Oct 17, 2014 at 9:03:43 AM
Page generation time: 0.5244
