Forums >> Revit Building >> Technical Support >> Crown mouldings on a brick wall?
Mon, May 25, 2009 at 3:02:10 PM | Crown mouldings on a brick wall?
brendanonstad
Im using a brick wall and cut an opening in it. The top is an arch and theres stairs leading up to the opening. Im wondering if I should put crown moulding around the opening of the brick wall. If I should, how do i?
Tue, May 26, 2009 at 2:51:27 AM | Crown mouldings on a brick wall?
tim123
4 Stars: 19 Votes
It depends on whether you need to.  If you need to show this because it is to be built and needs to be detailed then you can just use 2D drafting to show the brickwork to the arch.
If you want to see it in a rendered view, then you will need to model it.  The approach depends on what this actually looks like and how many there are.  If there are many, you could create a family for it.  If there's only one, do it as an in-place family, extrude a brick that is the correct shape, give it a material Cryingyou may need to create a new one as the standard brick wil show the jointing in the wrong place) and copy it or array it around the opening.  Do a single large extrusion for the mortar joints that does not protrude out as far as the bricks.  Give that a material.  If neccessary, cut a hole out from the wall where the brick detail occurs.
Sun, May 31, 2009 at 8:38:51 PM | Crown mouldings on a brick wall?
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
i did this just the other day, open a new profile family, draw the side sktch of the profile, change the material i brick, and load it into you project. then creat a new wall sweep and use the profile that you just made.
J. Allen Ball
Sweeps and window mouldings
Tue, Jul 31, 2012 at 1:01:54 PM
2-pick family visibility problem
Mon, Nov 5, 2007 at 8:57:25 AM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:30 PM
Crown Moulding Return
Thu, Aug 22, 2013 at 2:52:28 PM
Page generation time: 0.8469
