Forums >> Revit Building >> Technical Support >> Dimension line, line weights won't change
Sun, May 24, 2009 at 6:25:59 PM | Dimension line, line weights won't change
whitehamish
Hey all
I'm having trouble with my dimension lines. I have changed the line weight table to thiner lines and everything seems to change fine
except for the dimension lines, the remain thick when I need them to be thiner? any clues?
thanks
Mon, May 25, 2009 at 9:52:45 AM | Dimension line, line weights won't change
tim123
4 Stars: 19 Votes
Note that in the Line weight table there is a separate section for annotations.  Change it there for the dimensions.
Tue, May 26, 2009 at 6:54:21 PM | Dimension line, line weights won't change
whitehamish
Thanks Tim your a life saver
Dimension Line Weight
Fri, Oct 7, 2016 at 1:32:52 PM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Can't adjust Joist line weights
Tue, Nov 15, 2016 at 6:11:06 AM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Page generation time: 1.1930
