Forums >> Revit Building >> Technical Support >> Stairs in RCPs
Fri, May 22, 2009 at 11:12:50 AM | Stairs in RCPs
asbuckeye07
My stairs are showing only as the overall boundry in reflected ceiling plans.  This is happening even to stairs that are just treads (no risers or undermount), so if revit was just truly "looking" at the underside there should be lines arrayed at 10" or whatever.
Fri, May 22, 2009 at 1:15:34 PM | Stairs in RCPs
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
what type of stairs are you using and please post example
Fri, May 22, 2009 at 1:21:38 PM | Stairs in RCPs
tim123
4 Stars: 19 Votes
I don't think that you can automatically do this.  One method is to create a callout of the stair from the floor plan view, set the scale to be the same as the RCP, and place it beneath the RCP on a sheet.  It will snap to the correct position.
Tue, May 26, 2009 at 9:14:41 AM | Stairs in RCPs
asbuckeye07
great work around Tim, thanks!
It seems odd that revit wouldnt just show you what the stairs look like in actuality, but oh well
Room Tags in RCPs
Sat, Feb 11, 2006 at 3:03:52 PM
Potlight Symbolic Lines showing up on other RCPs
Mon, Mar 14, 2011 at 2:41:29 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Page generation time: 0.0868
